Advice on TH-42PE30...please
Discussion in 'Plasma TVs Forum' started by Zulu_UK, Aug 4, 2005.
  1. Zulu_UK
    My furniture arrived in South Africa after a long two month wait from the UK on Thursday last week. As you can imagine the first thing to be unwrapped was the TV. Bit of a nightmare to setup as our version of Sky out here (DSTV) does not use SCART as a form of connectivity. So I used a high end RCA kit with a SCART adaptor. This causes a small problem, when I switch on the TV it defaults to the built in tuner, I have to wait about 3-5 seconds for it to realise that there are no channels stored, then press AV then press the AV specific channel.
    Every time…….does not look so cool when you have to fiddle with the remote when you want to show some your new telly ! :suicide:
    Does anyone know of a way around this? :confused:
    Also what is the way of “running a screen in”….i just switched on and went for it !
    Thanks in advance !
    Other equipment –
    Sony DVP-NS430
    Sony STR-KSL50
    Panasonic DMR-ES10
