Advice on telephone sockets and broadband
Discussion in 'Networking & NAS' started by markyboy, Dec 7, 2004.
  1. markyboy
    markyboy
    Oct 7, 2004
    28
    I am about to install a basic telephone socket extension (as my main telephone socket is in the hallway and my PC (eventually) will go int the livingroom, which is about 10 metres away. I plan to run a 25 metre extension out through the external wall (as I have already laid my hallway floor and so can't install the flat telephone cable under the floor - and don't want to drill holes through doorframes) by my main socket and round the outside of the house coming in through the external wall to my living room and to my pc. I seem to remember people explaining how to install the broadband filter!!!! somewhere. But where would I put my filter ?? Would it be on the end of the extension or in between the main socket and the extension ??
    Also I plan to have an inline second socket next to the extention socket in the living room for the telephone. Would this arrangement work ??
  2. Synchro
    Synchro
    Nov 14, 2004
    4,123
    Chester
    +561
    You're ADSL Filter(s) will need to isolate any phones you have from the ADSL signal
    This is usually tidiest and easiest, between the phone and its nearest socket.
    If you place it between the main/master socket and the extension, it will look untidy.
    You do not need an ADSL filter between your PC and its phone socket as well i.e. no phones = no filters.
    If you have a phone next to your PC, you can plug your phone into the filter, like normal, but also plug your PC into the filter as well (seeing how you will only probably have one phone socket to use there). You don't need seperate sockets for phone and PC usage.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    If you already have multiple phone extensions then you will need a filter at each extension.
    If you plug a filter into the master socket and then the extension into that then you will be unable to use that extension with a phone. Therefore your best bet is to plug the filter into the end of the extension beside the PC, and then as stated above you can also plug a phone into that filter.
    Mark.
  4. markyboy
    markyboy
    Oct 7, 2004
    28
    Thanks MarkE19.
    Yes, I will have the phone in the living room next to the PC, so as the telephone socket will only be an extension to the main one in the hall, I don't need to bother havign splitters etc... and so will plug the ADSL filter in then the phone in the filter with the PC modem cable.
    I seem to remember seeing these filters as short 10cm wires which plug into the phone socket and have a LARGEish.. socket at the other for the telephone/PC modem.
  5. Gerbil
    Gerbil
    May 20, 2002
    265
    Newbury
    +23
    If you want something very neat and tidy and don't mind paying a bit more then you can always get a BT extension socket with an integrated filter to go in the lounge. Something like this
    You'd need the LJ4 model which has a filtered socket for the phone and an unfiltered RJ11 socket for your ADSL modem/router.
    ADSLNation do something similar.
  6. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    i could always send you a proper extension socket if that would make it look better for you, i have a few around i think, and i could tell you how to wire the thing up too.
    but you will need to use the filter in the socket though.
    let me know if this would help
