advice on speakers for home cinema
Discussion in 'Home Cinema Speakers' started by scouse, Jan 23, 2003.
  1. scouse
    scouse
    Jan 22, 2003
    285
    Balham
    +3
    I need some advice on which rear and centre speakers i should go for. I already have wharfedale valdus 400's for my two fronts and i was considering buying diamond 8.2's or 8.1's for the rears and the diamond 8.centre for the centre...what are peoples opinions on this??
    Any advice on a suitable AV receiver would be handy...i have an old JVC stereo amp already which seems quite good to which i would run the two fronts.
