Advice on Speaker Setup
Discussion in 'Home Cinema Speakers' started by suran, Aug 7, 2005.
  1. suran
    suran
    hi Guys,
    I've attached a layout of my room, and would kindly like one of you gurus, to suggest the best place to place my rear surrounds. I have attached a drawing.
    :thumbsup: :thumbsup: :thumbsup:
  2. oconnpad
    oconnpad
    Nov 29, 2004
    260
    +4
    I think you might be best trying not to include the sofa on the left hand side of the picture in your speaker placement plan.
    I'd probably just put you surrounds behind the sofa at the bottom of the picture, presuming this is where you actually sit.
    Your speakers will fill the room with sound so people sitting on the sofa on the left will here stuff just not as good sitting on the bottom sofa. Let the musical chairs begin when you get up of the sofa :D
  3. suran
    suran
    thanks
