Advice on speaker connections sought
Discussion in 'Home Cinema Speakers' started by wimbledon, Jan 10, 2004.
  1. wimbledon
    wimbledon
    Is it safe to connect more than one source to one set of hifi speakers? For instance apart from having speakers connected to my hifi amp I would also like to connect the left & right stereo channels from my prologic TV directly to the same hifi speakers, by-passing the hifi amplifier and the TV’s internal stereo speakers. I have left and right outputs on the TV to do this. Each speaker has available connects at the back for two sets of speaker wires. I seem to remember reading a long time ago that this is not safe practice as some of the connected equipment can fail.
    Many thanks, Andre
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    The two sets of speaker connectors on the back of each speaker are for biwiring them to the same amplifier. It is definately NOT safe practice to connect them to two different amplifiers
  3. eyerish
    eyerish
    your best bet is to use a speaker switching box, which aren`t very expensive. One set of cables gets connected from your speakers to the switcher and (I think) each source would go into the box. When you want to swith sources you can then manually swith sources. Your other option is to connect 2 phono cables from your hi-fi aux. to tv (if available). Then you can switch sources via your hi-fi....
  4. wimbledon
    wimbledon
    Thank you both for excelent advice - will stop me making an expensive mistake!
    Regards,
    Andre
