VivreSaVie88
Hi there!
I am setting up my home cinema for private use in my living room.
The conditions are as follows:
Hence, I was thinking of a 60''or 70'' screen (perhaps Duronic MPS80/43) and a XGIMI Halo+ hanging from the ceiling. I would of course recharge it between uses (or use it while being charged for longer uses) with a very long cable. But I do want the option to have a use up to 2h without cables.
I am however very much struggling to find ceiling mounts that seem compatible with the Halo+. Do you have any advice on mounts that are compatible?
Any other idea on the setup (would the screen be adequate for okay but not great darkness?)
Thank you!
Lorenzo
- dark but not perfectly dark when watching
- maximum 2.5 meters from the screen to the projector
- viewers on one row, on angles up to 40 to the screen.
- we would prefer avoiding objects on the ground (pets are a danger!) and avoid to always have ugly cables around (incuding the possibility to watch a movie without cables).
Thank you!
Lorenzo
