advice on setting black level
Discussion in 'Movie Forum' started by 7 of 9, Nov 5, 2004.
  1. 7 of 9
    7 of 9
    Apr 16, 2003
    235
    16
    kingswood bristol
    can someone give some advice on setting the black level aka brightness level on my tv for the best picture quality.
    thanks from 7 of 9
  2. Simon6776
    Simon6776
    Jan 7, 2003
    2,256
    West Sussex, U.K.
    +33
    Well, as a non-techie, I'll explain how I do it. Set the brightness in the room as dark as you would ever normally have it, then, assuming you don't have access to DVE (Digital Video Essentials), find a black frame on a DVD (usually at the start of the first chapter of a film) then pause it, so you have a totally black screen. Increase the brightness so that the black becomes grey, then decrease the brightness again, just until the grey disappears, and your screen looks turned off (if you know what I mean), or totally black. The adjust the contrast, so that whites looks white, but without 'blooming'. You may have to fiddle with both adjustments for a while until you get them right. The most important thing for me is that black looks black, and not a murky grey. I always find it's better to have a higher contrast and a lower brightness, than vice-versa.
    Obviously there are more technical ways to do this, which I am certain somone will explain, or you could use the THX Optimisers found on some Fox DVDs.
  3. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,302
    Surrey. UK.
    +2,016
    As Simon suggested, unless you have something like DVE (for PAL disks) or Avia (for NTSC disks), then the THX optomiser will be the next best thing.
    The only drawback is, the THX Optomiser is designed purely for the disk it's on, so can't really be used as a blanket calibration, but it will get you in the ballpark so to speak.
    Gary.
  4. 7 of 9
    7 of 9
    Apr 16, 2003
    235
    16
    kingswood bristol
    i have recantly used ultimate dvd platinum system calibration disk (ntsc) and thx optimiser from on star wars ep iv (pal) and get different results which settings should i use.
  5. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,302
    Surrey. UK.
    +2,016
    If the pj has memories for each input and type, then it will remember the different settings for PAL and NTSC. Both systems have different levels for black, so thay will have different settings for brightness at least.
    If it isn't able to distinguish between ntsc or pal differences from the player, then have a look and see if the player has 0ire or some form of black level setting for ntsc. Sometimes you can set the black output for ntsc to the same as pal, so they will bothe be the same when calibrated.
    HTH
    Gary.
