Quantcast
Advice on seperates alternative to DAV?
J
jonners
I was considering buying a Sony DAV C770 or S880 but having read the postings on this forum it seems that the money may be more wisely spent on separates.
I dont want to start another DAV flame war but is there any chance you could recommend a seperates option which would out perform the sony for the same or less cash? I was looking in the £550 to £680 range. Good looks and inobtrusive units would be a preference but performance is my main objective.
Can it be done or is the DAV the best option at that price?
J
jonners
Does the DAV rule then? I was considering looking at options other than the DAV but if nothing can compete ...
