Advice on selling an LCD TV
jp_bl_68
I've got a 20" Samsung LCD with about 4 years left on a Richer Sounds 5 Year TV Warranty, comes in it's original box, all original leads, remote control (with batteries) and an antenna, that I'm planning to sell but I've no idea what it's worth:
Samsung SyncMaster T200 HD
20" Widescreen
Brightness 300cd/m²
Contrast Ratio DC 10000:1
Resolution 1680 x 1050
Response time 5ms
Viewing Angle (Horizontal/Vertical) 170˚/160˚
Colour supported 16.7M
Video Signal Analog RGB, DVI, HDMI, Component , TV (Digital TV / Analog TV)
Sync. Signal Separate H / V, Composite
Connector 15pin D-sub, DVI-D, 2HDMI, Component, DTV Tuner, Optical Out, Scart, Cl Slot
Power
Power Consumption 50W (Max.)
Standby Power (DPMS) < 2W
Plug & Play DDC2B
Multimedia Speakers 3W x 2Ch (SRS TruSurround XT)
Special Features Built-in DTV (DVB) Tuner, Sound: SRS TruSurround XT. Optical digital sound (SPDIF). Component, HDMIX2, Supporting 1080P Input, CI Slot
Mac compatibility Yes
Cabinet Colour Rose Black
Accessories Remote Controller, D-Sub Cable, DVI-D Cable
Product Dimension (With stand, WxHxD) 486 x 417.5 x 215mm
Product Dimension (Without Stand, WxHxD) 486 x 350 x 86mm
Shipment Dimension (WxHxD) 559 x 493 x 152mm
Product Weight 5.6kg
Shipment Weight 7.5kg
Original box and packaging
Manual
Remote control (including batteries)
Power cable
D-Sub Cable
Simple antenna
Amazon and Ebay are still selling these for £200 which seems far too expensive for a 20" LCD. Any idea what this is actually worth?
I hope I've posted this in the right place and that I've not broken any forum rules in doing so, I apologise if I have.
jp_bl_68
Ah, it seems I was in the wrong place. Sorry about that. Thanks for moving this to the right board, Curly99 :thumbsup:
Podcast: Sony A90J Thoughts, madVR Processor & Sonus faber Lumina II Reviews + Movie & TV roundup
