Adam R
Established Member
Hi all, I have the following set up & i'm looking for a decent 5.1 speaker set on a budget:
Panasonic TH42PZ85BA
Sky HD Amstrad box with Optical & Coaxial out
PS3 Optical out
Xbox 360
I am probably going to spend about £150 ish on an Amp so will eventually have around £200 to spend on a 5.1 speaker set.
I am looking for possibly 4 bookshelf a centre & woofer or a satellite package with woofer. I have had a look on places like Ebay & Richer Sounds but I know nothing about speakers or Amps & find it all a bit of a mine field.
I have seen a local ad for some Sony SS-TS551 Speakers & SS-WS551 Sub Woofer. these as I understand were from the Sony DAV-S880 Home Cinema package but I was windering if they were likely to work from a seperate Amp?
The surround sound tower speakers have 4 x 50mm Bass/Mid Speakers and 1 x 25mm Tweeter with 2 Ports in each unit & are 100 Watts RMS
The Sub is 100 Watts & 3 Ohms Rated Impedance (whatever that means)
I really like the way these speakers look & they have to be better than My current surround sound setup of the following:
Acoustic solutions DS533: Subwoofer output power 35 watt RMS
Output Power 5 x 7 watt RMS
So, any help will be welcome.
Thanks in advance.
PS3 Optical out
Xbox 360
Thanks in advance.
