Advice on scalers
Discussion in 'Projectors, Screens & Video Processors' started by Magic, Feb 5, 2003.
Thread Status:
Not open for further replies.
  1. Magic
    Magic
    Nov 27, 2002
    562
    Colchester
    +10
    I'm a bit confused on the relative merits of de-interlacers (like the iScan Pro) comapred to scalers (like the Quadscan Pro). I've searched through as many threads as I can find, and also picked Chris Frost's brains, but I'm still uncertain.
    Given that these are the most affordable 2nd hand purchases, and are similarly priced what are the relative advantages/disadvantage of each unit?
  2. popeye
    popeye
    Feb 12, 2002
    779
    19
    Leeds
    Have a look on the progressive scan & video processing forum. there's lots of information on the iscan & Quadscan Pro.
    If you do a search I seem to remember not so long ago there was a thread titled Iscan Pro vs QS Pro.
    I've previously owned both these units and the iscan will be a far better prospect for you. The only draw back is that you will be restricted to doubling with an iscan, however if your looking for quality the iscan is in a different class. The other solution is to invest in a CS-1.
    All the best!
    popeye:hiya:
  3. Magic
    Magic
    Nov 27, 2002
    562
    Colchester
    +10
    Thanks Popeye,
    Sorry for being such a dunce about this. All the stuff I want seems to be in the Progessive Scan forum. Never even noticed it was there before.
  4. GaryG
    GaryG
    Nov 20, 2002
    744
    Shropshire
    A de-interlacer does just that, the picture size stays the same. A scaler, in addition to de-interlacing, can change (scale) the size of the picture, usually to match the pixel elements in a plasma or projector.
Thread Status:
