Advice on reasonably priced All-In-One
mark_dubo
I currently have a 50 inch plasma with a PS3 connected via HDMI, Xbox360 connected via HDMI, Wii connected through component and virgin media connected via scart.
What I'm after is a home theater system I can plug all these into with only one lead (HDMI) going to the TV. Has anyone got a similar setup? Or can anyone give me a recommendation?
P.S I'd like a system in black.
Chilly Willy
Hi Mark
Before buying a home theater system you may want to look at these links:
http://www.amazon.co.uk/HDMI-Tri-Link-Switcher-PS3/dp/B000NJZRSI/ref=pd_ecc_rvi_1
This will help you with your set-up using 1 HDMI lead.
http://www.maplin.co.uk/Module.aspx?TabID=1&ModuleNo=35241&doy=29m6
This may help if your present system has got a optical input. If not and you want to upgrade, then look at HT systems that have an optical input.
:thumbsup:
1nsomniac
..after looking at the £600 onkyo... the £200 jvc still looks the better option...:rolleyes:
but how is the JVC? im also tempted to buy this when it comes back in stock on play.
holliefabbabe
just out of intrest , how many of us have bought on off play.com and are still waiting for them to come into stock , ive been waiting since 24 dec
