Advice on Quintro setup issue
Discussion in 'Plasma TVs Forum' started by snakeeater, May 30, 2004.
  1. snakeeater
    snakeeater
    Jul 26, 2003
    Okay this is mainly directed at any fellow Quintro owners.
    I recently purchased a Panasonic 42" plasma TV. With this I had a Quintro scart switcher. I have a slight problem which I hope some of you guys can advise me on.
    It has 5 scart sockets on the back. I have nothing plugged into 'scart 1' as this seems to be a low quality scart socket which delivers a fuzzy picture. In scarts 2, 3, and 4 I have an xbox, Sky, and DVD player which are all fine.
    the problem is that I want to connect my Playstation 2 to 'scart 5', however when I do this is is not detected and cannot be selected by using the quintro remote as ther tv just reports 'no signal'. I cant use 'scart 1' because it delivers a fuzzy picture. So in my case I only really have 3 scart sockets on the back of the quintro that seem to be of any use.
    Is there any reason why 'scart 5' seems to be redundant and is 'scart 1' of a lower quality or do I have a problem with that particular socket.
    I know I could connect the PS2 directly to the Plasma via a different connection method but I want to minimise the amount of cables I have running to the screen.
    Any advice would be very much appreciated :smashin:
  2. snakeeater
    snakeeater
    Jul 26, 2003
    Am I the only Quintro owner here?
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,549
    The Borders
    +3,024
    snakeeater
    How is the Quintro attached to your Panasonic Plasma?
    If you bypass the Quintro does your PS2 work if you hook it directly to the Input the Quintro normally lives on at the Plasma?
    Best regards
    Joe
