advice on purchase - Toshiba/Sony
Discussion in 'Blu-ray & DVD Players & Recorders' started by ag005613, Aug 7, 2002.
  1. ag005613
    ag005613
    Jun 21, 2002
    52
    I have been looking around for a while for a relatively cheap DVD player to plug into my home cinema - I currently use my PS2 but am looking for something with better video and sound definition. I am no expert here though so am looking for some advice.
    There seem to be some good deals on the Richer Sounds Website - I have picked out the following in the clearance section:
    Toshiba SD100E (£69)
    Sony DVPS375 (£149)
    I have also seen favourable reviews for the Toshiba SD220 which is available for £134.
    I would like a multi-region with DTS, DD 5.1. VCD is not a necessity but would be nice. Anybody help me choose or even offer other idea? Thanks.
  2. mrbluesky
    mrbluesky
    Hello there
    like you I have just upgraded from the PS2
    I went for the Toshiba SD220 and I am very happy with it
    good luck
    M
