Advice on plasma purchase for theatre auditorium
Discussion in 'Plasma TVs Forum' started by Joon, Mar 16, 2006.
  1. Joon
    Joon
    I would like to buy a 42" screen for the theatre I work in for the foyer to show (low bit rate) feeds from the auditorium and DVDs. It will be set up high. Because of the low quality feeds etc am I better getting LCD or Plasma? If so which, I have approx £1200 to spend. Any help much appreciated..
  2. sbowler
    sbowler
    Mar 24, 2005
    3,799
    Leeds
    +481
    I would go for the LCD option merely on the life of the panel which should be double that of the plasma. But you could always get two cheapish plasmas, LCDs of 42inch are very expensive.
  3. runner05
    runner05
    Jan 15, 2006
    440
    +13
    il think u find that new plasmas have much longer lifes than previous, something like 60000hours, thats some thing stupid like 20 years constant running:hiya:
  4. HoTTdog
    HoTTdog
    Feb 7, 2006
    190
    Kent
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Tescos, Sainsburys, B&Q, HMV to name but a few run PWD panasonics for public display. We've put them in NHS hospitals, estate agents, and a lot of private homes of course. It's the man for the job.
