Advice on new system
deniewibly
Hi all
I'm going to replace my current MB/CPU with a Core Duo 2.40Ghz 1066 FSB and an Asus P5B. Can anyone give me some good recommendations on what RAM to get (2Gb).
I'm replacing a P4 2.4ghz, will I notice a massive increase in speed? I mainly work with Adobe Premiere and Adobe After Effects and they are very CPU intensive apps so am looking for a big performance boost.
Dene
miceri
Always buy from the big names - I have had alot of trouble in the past from 'budget' offers.
If moneys tight try CorsairValue DDR2, errm good value. stay away from Kingston!
If moneys no prob, then also look at OCZ - Bling bling, decent price and good OC potential...
