Advice on new setup
Discussion in 'Projectors, Screens & Video Processors' started by Gadfium, Dec 23, 2003.
  1. Gadfium
    Gadfium
    Nov 2, 2003
    278
    Morecambe
    +24
    Right then, this is the plan.....
    I have a small garage that I want to convert into a dedicated home cinema (currently got 32" Philips, Sky+, Panny SA-HE7 and Sony DVD in sitting room). The dimensions are on the small side (about 14' x 8') and as such am looking for sound clarity more than outright loudness!!
    I have a budget of about £3000-3500, and want to spend about £2-2.4K on the PJ. The rest is for the DVD, Amp, speakers, cable and screen. I might consider a HCPC (if it can be justified). In addition, I will probably pipe Sky in from the front room (I have ruled out getting another Sky box as I have 2 subs at the mo' and aint going to pay any more to Murdoch & Co)
    Two questions:
    1) Is the room too small for a HC???
    2) What would you recommend??
    Ta in advance
  2. Kramer
    Kramer
    1. Nope :)
    2. Read through the last few weeks posts for ideas.
    :smoke:
