Advice on new AMP Please
Discussion in 'AV Receivers & Amplifiers' started by Norman, Sep 24, 2004.
  1. Norman
    Norman
    Jul 14, 2000
    1,644
    116
    Herne Bay
    +514
    Now that my needs have changed I am looking to replace my Yamaha DSP-A1 with something much smaller that can easily be hidden away.
    I have two options, one is a completely integrated home cinema system the other is a much smaller AV Amp like the Denon 770 coupled with my Toshiba 900e DVD player and Bose speakers.
    Any integrated system must be fully multi region and support NTSC & PAL Progressive scan.
    Eagerly awaiting your recommendations (Budget within reason isn’t a consideration, compactness and good performance is).
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
