Context of problem:
First a bit of context setting to help with the questions I've listed below.
I've got a BT Home Hub 5 and live in a single level apartment constructed early 2000s, stud wall, with living room and two bedrooms. I'm on unlimited BT Infinity 2 but its probably called something else now.
I'm using BT Broadband Extender Flex (the black ones 500 model, all passthrough) one is situated next to Home Hub. The other 2 are in the living room and small bedroom (used as an office). The extender in the living room is a 3 port ethernet that connects the BT TV Box (retail version) and games consoles. This is situated on the other side of the living room to the home hub. The extender in the small bedroom is a single port ethernet which connects via a cable to a desktop computer.
Now sometimes I have to hold and press the link button at the top of the Flex extender in the home office to get the internet to work. It does this at least once a day. Every so often the BT TV box tells me its disconnected and I have to reconnect and sync the extender with the one plugged into the homehub. This is once every few weeks. I tried using TP Link smart plugs in different locations across the apartment and these just lost connection, or stopped working after a while. I gave up with smart plugs and had a different broadband extender to BT initially, but the BT branded ones seem to play nicer with the homehub. I don't have them plugged into extension leads, but I do have extension leads running from the passthrough on the broadband extenders. I have tried both with and without the extension leads plugged in, but it doesn't make any difference to the temporary disconnections.
A friend has advised that I can ditch the network adapters if they glitch and use the BT whole home dishes instead. My understanding is that I would require a network switch to plug into the dish with enough ports for each of the consoles, or smart devices in the living room.
I find that I can have a few things streaming around the place and then something needs to give. For example, if I use Wi-Fi on smart phone to watch a youtube video then I find streaming will pause elsewhere then re-start after a while, or the connection to the desktop PC will drop out. When I plug a laptop into the homehub directly and test the speed it is at the maximum (70mbps - I think? In fairness it has been a while since I've done that). Obviously, there have been slow downs due to number of users at home during these difficult times, so I'm not expecting it to be super speedy every minute of the day.
As if that wasn't enough, I am thinking about adding to my woes and would like to sync music between the living room and bedrooms through smart speakers, e.g. sonos, but I'm wary about buying them if the home Ethernet/Wi-Fi solution couldn't cope with smart plugs dotted about the place. I don't have smart heating, or anything else like that. I use Wi-Fi in the bedroom and have a fairly decent signal to stream music from an ipad connected via usb to the stereo. It would be nice to be able to connect to the internet via ethernet from the main bedroom, but it is not end of the world stuff if this proves to be a step too far.
Questions:
Which is more stable the BT dishes, or the plug in broadband extenders?
What's the best Ethernet switch to get for either the dishes or extenders? For example is it worth getting a 10/100 if I'm using a 500 model extender? Or should I opt for a 10/1000 if I'm using the dishes?
Or should I just carry on as I am with the occasional drop outs and forget trying to add anything else to the existing network?
BT haven't offered me a homehub upgrade in ages? Should I ask for the latest one, or is that not the problem? They keep offering me faster speeds though, but I'm not convinced it is the speed that is the problem on my set-up.
Any advice and suggestions both welcome and appreciated. If this post needs to go somewhere else then no problem, or if it has been discussed before then please send a link to the info.
Questions:
