Advice on moving Virgin set-top box upstairs to same room as broadband
Discussion in 'Cable TV & Virgin Media TV' started by Toto Man, Sep 8, 2007.
  1. Toto Man
    Toto Man
    Aug 25, 2007
    67
    We got NTL in approx 5 years ago. They installed the TV point into the downstairs living room and the broadband into my upstairs bedroom, by running 2 separate cables from the box outside our house. I now want to move the STB from downstairs into my room upstairs.
    I tried hooking the STB upto my broadband point and everything seems to work fine. But obviously I'll need a splitter so I can use the internet and TV at the same time.
    I've unscrewed the white plastic NTL covering and there is a 0.4dB isolator fitted with a single input and a single output. Can I fit a 2-way splitter after this without causing significant degration to the signal strength going to the modem and STB?
    Is there a better way of doing this? Is there such a thing as an isolator that has 2 outputs instead of 1? This would make things simpler!
    PS - I've not ventured into the outdoor box yet. I guess a possibility would be to reroute the cable coming in downstairs to upstairs, but that would involve a 50ft ladder up the side of the house so not my preferable choice!...
    Cheers,
  2. OneTrouble
    OneTrouble
    Aug 20, 2007
    640
    28
    +28
    cable splitter..99p..job done
    try maplins..about 3.99 or egay for 99p
    will work with a splitter no problem
  3. Toto Man
    Toto Man
    Aug 25, 2007
    67
    So do I replace the isolator with the splitter or add the splitter after the isolator? Also will I need to put a shorting plug in the now unused point in the downstairs living room?
    Also, should the splitter be 5mhz-1000mhz or would a 5mhz-2500mhz one do a better job?
  4. essjay
    essjay
    Jun 7, 2006
    925
    43
    +110
    A 5Mhz - 1000Mhz should be fine as most of the cable network only goes to 750Mhz.
    Let me have a dig around I might have a spare one I can post to you.
  5. Toto Man
    Toto Man
    Aug 25, 2007
    67
    very kind of you but there's no need. there's a maplins a few miles from me so i should be able to get one there. but what i need to know is if i need to run a cable from the isolator to the splitter? or does the isolator get removed? (i've never attempted to crimp a coax myself before)
    EDIT: i think this might just be the ticket: http://cgi.ebay.co.uk/2-Way-Cable-S...ameZWDVWQQrdZ1QQcmdZViewItem#ebayphotohosting
    are all two-way splitters more or less the same when it comes to dB signal loss?
  6. essjay
    essjay
    Jun 7, 2006
    925
    43
    +110
    That should do the job very nicely. The loss should be 3.5db on each leg
  7. Ben
    Ben
    Feb 19, 2007
    1,417
    Tunbridge Wells
    +263
    Just to confirm: you can fit the splitter after the isolator. Also, if you measure the lengths of coax required, you can buy pre-terminated lengths of coax - meaning you don't have to crimp it :)
  8. Toto Man
    Toto Man
    Aug 25, 2007
    67
    Thanks guys. Will let you know how it all goes :) .
  9. willsy2
    willsy2
    Apr 22, 2005
    643
    28
    Newcastle
    +32
    I just used the twist on F-Plugs Here and Satellite coax on mine - about a 10-12m run. Been working fine for a couple of years with no problems
