Advice on Mobo/CPU/Memory for £350
Discussion in 'Computer Components' started by RICK..., Feb 21, 2014.
  1. RICK...
    RICK...
    Nov 21, 2008
    35
    Nottingham
    +3
    As per title! I've re-ignited my love for WoW after being away for nearly four years and my computer just isn't cutting it any more.
    Ideally I want to keep my graphics card for the time being, with a view to upgrade in a few months time.
    All I need for now is motherboard, cpu and memory and have a budget of £350ish for those.
    I've found this bundle but unsure if it's any good?
    ReFlex Gigabyte Z87 - Intel Core i5 4670K @ 4.2GHz Configurable Gaming Bundle [BU-001-OG]
    Looking to buy today/tomorrow so any advice appreciated :)
    edit - current GFX is GeForce 8800GTS. I'll be using my PSU also which is a Corsair HX650
  2. spyder viewer
    spyder viewer
    Dec 18, 2007
    5,846
    2
    Kent, UK
    +1,285
  3. RICK...
    RICK...
    Nov 21, 2008
    35
    Nottingham
    +3
    Thanks will have a look.
  4. RICK...
    RICK...
    Nov 21, 2008
    35
    Nottingham
    +3
    Ordered the same bundle but from Novatech as it was cheaper and quicker delivery. Thanks!
    I've got the bug now and thinking about just buying a new GFX card. Any recommendations? £100-150 budget.
  5. hellomoto21
    hellomoto21
    Dec 4, 2012
    219
    +10
  6. RICK...
    RICK...
    Nov 21, 2008
    35
    Nottingham
    +3
    Thanks.
    Is it worth spending the extra £15 and getting the 270x, or is there not much in it?
    Yeah the 8800 is ancient now, was the dogs gonads when I bought it though!! lol
  7. hellomoto21
    hellomoto21
    Dec 4, 2012
    219
    +10
    Up to you really, same card but the 270 is about ~900mhz core and the 270x is ~1ghz. I would just get the 270 and oc it to match the 270x.
    The 270's are best £/mining rate card so fairly good price for the performance.
  8. RICK...
    RICK...
    Nov 21, 2008
    35
    Nottingham
    +3
    Okay thanks.
    Is there any big differences between the different brands of the 270, I.E Gigabyte etc? Is it just the cooling that's different? and are they all easily overclocked?
  9. hellomoto21
    hellomoto21
    Dec 4, 2012
    219
    +10
    Personally i would go for the msi one, that i linked, ive never had any problems with msi cards and ive had a few psu's go bang. Would stay clear of xfx rtbh.
    The gigabyte also looks decent aswell, (Gigabyte Radeon R9 270 OC AMD Graphics Card - 2GB - GV-R927OC-2GD - Scan.co.uk
    "So, after some benchmarking with unigine heaven, I have settled on core speed of 1155MHz, and memory set at 1499MHz. I also set the power limit to the max. With the somewhat arbitrary settings(though the same for each test), I was able to increase my FPS from 58.2 at out of the box settings, up to 67.8, give or take a few tenths of a frame. And this card starts out a little faster than the standard 270 to begin with." hope that helps, either card should be able to reach 1ghz core fairly easily :).
    The gigabyte card does have 2x6pin connectors rather than 1 so probably better for a high OC, also depends if you psu has enough connectors.
  10. RICK...
    RICK...
    Nov 21, 2008
    35
    Nottingham
    +3
    I nearly opted for the Gigabyte but I've gone with the MSI, £131 delivered which I think is pretty good.
    Spent all morning comparing them but the MSI seems to have been tested more widely than the Gigabyte.
    Thanks for all your help, very much appreciated! :)
