Advice on integration to 3D
Discussion in 'Blu-ray & DVD Players & Recorders' started by desti, Sep 11, 2012.
  1. desti
    desti
    Sep 9, 2012
    HI all first post, think its in the correct thread. I am looking for some guru advice. Price range can be cheap to expensive but would like both options
    I have just purchased this...
    Samsung UE50ES6710 50-inch Widescreen Full HD 1080p 3D Smart TV with Built-in Wi-Fi and 2 Pairs of 3D Glasses - White (New for 2012): Amazon.co.uk: TV
    I currently have this surround sound system HT BD 1252.
    http://downloadcenter.samsung.com/content/UM/200907/20090723201549953/HT-BD1250A_ELS_0629.pdf
    The speakers are all 3ohm.
    I understand that it probably does not do 3d, I might be wrong though..? Do i purchase a 3d player and connect it to my existing system say through the optical in or do I by a new stand alone player/surround system and try and use the existing speakers?
    If so what and where? :lease:
