Advice on input source volume levels
Discussion in 'AV Receivers & Amplifiers' started by muscat, May 5, 2002.
  1. muscat
    muscat
    Apr 22, 2002
    44
    Radnage
    I have a Sony DA-50ES receiver at present. One of the aspects I don't like is that volume level on the integrated tuner is higher than the volume level on other external input sources, TV, DVD, etc. While some input sources have independent volume controls to compensate for this, other such as my DVD player do not. It would be preferable if all input sources had the same volume level.
    I am considering changing, with the Denon 3802 being my first choice. Can anyone advise if there are any similar problems with the Denon. I believe that some receivers allow you to set input source volume levels independently to ensure consistency but I am not sure which ones do and would be grateful for any advice.
  2. Zig
    Zig
    The Denon allows +/- 12db settings for each component.:cool:
