rags
I currently have 4 ceiling speakers installed in my living room which are wired back to a Sonos Connect amp. The speakers are Revel 783s which are 8 ohm impedance.
The living room is fairly large and has high ceilings (measures about 11m x 7m x 3m) and whilst the current amp and speakers do a reasonable job (I also have a Sonos sub in the room) I would like to add another pair of speakers and upgrade the Connect Amp to the new Amp which is more powerful and I believe can handle running 6 speakers simultaneously.
Currently all four speakers are wired individually back to the connect amp so there are effectively 4 pairs of speaker wire going into the binding posts of the amp. The speakers are installed towards the four corners of the room (the front two are a pair and the rear two another pair). I would like to add another pair in between the existing speakers but dont have the luxury of wiring them back to the amplifier so I need to chain them off the existing speakers. Can someone please advise the options to do this and what you would recommend?
Thank you
Thank you
