Advice on HD panel - 720p or wait for 1080p?
Discussion in 'TVs' started by richard plumb, Jul 18, 2005.
  1. richard plumb
    richard plumb
    Jan 27, 2002
    14,346
    Windsor
    +1,028
    Some context: I have a philips 30pf9975. Lovely screen, no native 720p support (idiots).
    So I have a great panel for SD TV, but nothing for my upcoming Xbox 360/PS3/SkyHD.
    Now, do I upgrade quickly to a cheapish £1k 720p HD ready panel (effectively a straight swap) to give me native 720p, or hold out using 1080i until I can jump to 1080p?
    In your opinions, is 1080p a long way off for broadcast? If so, would it be better to get a nice simple 720p compatible panel now, and then wait until 1080p front projectors are available, which will presumably benefit more from the increased resolution?
  2. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,080
    +681
    In my opinion 1080p is quite a way off for broadcast in the UK - it isn't a standard that is supported by the forthcoming Sky HD box (that is 1080/50i and 720/50p - though it will carry 1080/24p and 1080/25p native material in one of these standards)
    However it is possible that HD-DVD and BluRay will output 1080/24p or 1080/25p - as it is highly likely that these will be the "on disc" recording formats.
    However 1080/50p is highly unlikely in the immediate future - as a production format it is not particularly well developed, and AFAIK no proposed transmission system for this format in Europe.
    There are still benefits in having a 1080p native display - if it is a square pixel device (LCDs and DLPs usually are, plasmas quite often aren't) then it will probably have a 1920 horizontal resolution which may provide better quality viewing of 1080/50i stuff (as that may well be 1920x1080).
    I'd wait until Sky have launched their service and you see the mix of 1080 and 720 content - and also it may be worth waiting to see what HD-DVD/BluRay actually deliver.
    I doubt screens are going to be getting more expensive as time goes on - so if you are happy with your current panel then I'd wait until HD sources are available before you make your decision.
  3. richard plumb
    richard plumb
    Jan 27, 2002
    14,346
    Windsor
    +1,028
    Thanks.
    I'll try and resist making a quick decision - my current screen *should* work with xbox 360 pretty well, at least long enough for me to see how its panning out.
    And I already have an AE100 for movies, so I prefer bringing out the big screen when needed, so I'm OK with the idea of leaving 1080p to that if its a bluray/HD-DVD thing only.
  4. zag2me
    zag2me
    Nov 24, 2004
    228
    +17
    Remeber the Ps3 has support for 1080p. But thats still a year off.
  5. richard plumb
    richard plumb
    Jan 27, 2002
    14,346
    Windsor
    +1,028
    For ps3, I'm mostly thinking of movies, and that can just be bluray/HD-DVD. And I think that means a front projector for scale.
    PS3 games I think will most likely be 720p as standard, with perhaps a couple of Sony published titles pushing the boat out
