Advice on floating TV/AV Unit
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by mailrush, Feb 28, 2013.
  1. mailrush
    mailrush
    Feb 26, 2013
    Hi guys, first post so please be gentle
    I'm moving into my first place soon and will want to sort out a neat tv/av unit arrangement. The living room isnt the widest so i want to keep units to a minimum.
    I'll be fixing a 47" tv to the wall but want some kind of unit to sit underneath it, floating if possible.
    The image attached 'Hack Finished' i found on ikea hackers and fancy something similar without the hassle of building it.
    The other image i found on here and like the dwell floating shelf but im not sure if it will be high enough to house the sky box, ps3 etc. i dont like the floating shelf so much - can this be removed?
    Any other ideas where i can get something like this?
    One more thing - the wall i want to install on i think is stud partition. Will this be a problem in fixing a floating unit to?
    Thanks for any help in advance
    J
