Trizcakes
Hi, so I'm wanting to make my sunroom into a make-shift Cinema room. It's going to be a duel purpose room as opposed to a dedicated cinema room.
So far I currently have nothing purchased and want to start the work asap, but need to know what equipment is going in the room, such as the projector and speakers etc, so I can get the wiring all sorted etc..
Attached is a floorplan of the room, along with pictures (Currently used as a dumping ground, so ignore the complete mess) None of the furniture you can see is being used in the cinema room.
My question is, what would you recommend for this sized room?
Design intentions:
I'm going to be getting the walls and ceiling plastered, and then will paint the walls cream and the ceiling a navy blue (Remember this is a duel purpose room, so although black is preferred, it'll be too dark for normal use)
Then I intended to have navy blue black out curtains around all 4 sides of the room
(Possibly these: Luna Brushed Navy Blackout Pencil Pleat Curtains | Dunelm)
and change the hanging light to 6 halo spotlights spread across the room
However I'm not sure on which projector to get or what sound system to get. It doesn't need to be anything fancy fancy, like I don't have a budget per se, but I don't wanna be spending 4k on a projector, I'm thinking like 1k max, and as for sound system, as it's a smallish room, then I imagine something averagely priced should do it?
I purely intend to just watch things streamed from the internet such as Netflix, Amazon Prime, Disney+, ITV Player etc.. so realistically I can just hook up a smart device that allows all those apps to be installed to it, (such as an amazon fire stick or similar)
All advice and links to products are appreciated and suggestions of course!
Thanks in advance!
Design intentions:
Thanks in advance!
