Advice on DVD Recording
Discussion in 'Blu-ray & DVD Players & Recorders' started by Paul Swires, Oct 5, 2003.
  1. Paul Swires
    Paul Swires
    My partner and I already own a Sony dual format DVD writer and he quite successfully authors and burns DVD's for our clients ( mainly wedding and small events ) We are however looking at a DVD set top recorder for my place. My questions are the following. Can I author a DVD on my PC using a standard authoring program like Uleads DVD Workshop then burn to the DVD recorder like I was burning to a writer. In other words I do not want to use the DVD recorders own features for menus and chapters etc as I have heard that these are generally not as powerful and flexible as those made from a PC ??? If this can be done then would a HDD/DVDR still be beneficial.
    Regards
    Paul Swires
  2. PhilipL
    PhilipL
    Jan 18, 2002
    3,787
    103
    +421
    You can not author from a PC to any set-top recorder. You would need a PC Writer to achieve what you want.
    Regards
    Philip
  3. Paul Swires
    Paul Swires
    Thanks Philip. I read elsewhere that some new DVD Recorders for 2004 would have USB2 ports on them and was wondering if this might be for PC interfacing and might achieve my objective .... not quite sure ??
    Paul Swires (South Africa)
  4. PhilipL
    PhilipL
    Jan 18, 2002
    3,787
    103
    +421
    It remains to be seen if these ports would allow authoring, or would just be present for transfering MP3s, Images etc.
    Regards
    Philip
