Advice on Denon2200
Discussion in 'Blu-ray & DVD Players & Recorders' started by chris, Oct 18, 2003.
  1. chris
    chris
    Nov 20, 2000
    1,216
    romney marsh, kent, uk
    +28
    Can some one please tell me, what size video buffer this player has.....???
    Some sites say 8 meg, while others say 2 meg.
    If it has the 8 meg then there prob will be no layer change...but as i belive it (from what i have read), the 2 meg buffer still shows the layer change.
    I have tried the 2900, but sent it back, so thought i would give the 2200 a try.
    Any help please......
    cheers...chris.
  2. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +214
    I can't help directly I'm afraid, but from what I've read, a layer change can cause a cache flush, so you would notice a pause regardless.
  3. chris
    chris
    Nov 20, 2000
    1,216
    +28
    i think that was denons excuse (haydon labs), when people started complaining about the dvd700(it had the 2Meg buffer).....but i had a 2900 and not once did i see a layer change.
    I just thought that seeing as the 2200 has a diifferent firmware to the 2900 it might not have the probs that i noticed......but i dont want to get one if its got that annoying layer change.
  4. Fingolfin
    Fingolfin
    Hello!
    The 2200 has 8mb buffer. I've tested the layer skip thing and you won't see any layer change skip! Guaranteed!
    Take care
    F.
