Hi!
I am thinking of buying the AVR-1909. I was wondering if you can answer the following questions:
1) Does it support full SACD and DVD-audio via HDMI without any limitations?
2) Does the remote have a button dedicated to each source, rather than a single button to activate each source in turn?
3) Do all video coming from digital and analog sources go through the HDMI?
4) Finally, do I need an HDCP-compatible TV even if I do not use Bluray? My TV is a bit old, and it supports DVI. I was thinking of using an HDMI-DVI convertor, but I am not sure the TV supports HDCP. The manual seems to imply that if you do not have an HDCP TV, the signal will not come out correctly.
