Advice on connecting up Sky+, a Denon and a Panasonic Plasma
Discussion in 'Cables & Switches' started by inkinoo, Oct 16, 2003.
  1. inkinoo
    inkinoo
    Oct 16, 2003
    3,271
    London, England
    +244
    Could I ask for some quick advice on the best way to connect up my AV equipment now that I have a brand new Panasonic plasma in the equation?
    I have the component board for the WD6 so connecting my DVD player is not a problem. Only issue is Sky+.
    Currently, I go Sky+ to Scart to S-Video to Denon Amp then S-Video to Scart to Panasonic. Quality is not fantastic but then I expected that with Sky+. Tried going straight Scart to Scart from Sky+ to Plasma and didn't notice any difference.
    Question is, will the quality get any better if use the JS Technology RGB to Plasma VGA converter? And if so, are we talking a lot better?
    Thanks,
    Gerard
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    I don't think it will make any noticable difference, what you should look at is a briteview or ISCAN ultra.
  3. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    inkinoo,
    - was the Sky+ set to RGB when connecting to the scart board?
    - does your amp have multiple component inputs? (i.e. you could use the RGB to Component converter and run YUV up to the plasma)
    Failing that a video processor is the only way of improving the picture
  4. inkinoo
    inkinoo
    Oct 16, 2003
    3,271
    London, England
    +244
    1) Yes, Sky+ is set to RGB
    2) It's a Denon AVC-11SR so yes it has multiple component inputs
    Just looking, the video scalers are £400+. At the moment the picture is more than watchable. Spending £100 on an RGB to Component converter I assume will improve the quality. Spending £400+ on a scaler will also improve the quality.
    Essentially I am asking is the improvement with the scaler worth the money?
    Thanks,
    G
