Advice on connecting av gear to 435xde
Discussion in 'Plasma TVs Forum' started by BIGMAX, Mar 15, 2005.
  1. BIGMAX
    BIGMAX
    Jan 11, 2005
    747
    +18
    Hi all,
    Got my 435 xde set up with DVD player (through HDMI) and Sky+ through RGB Scart.
    I am running the sound through my existing Home cinema (Which I will be changing to new amp and speakers in the future) using an optical cable from the home cinema into the XDE MR. This gives me sound from Sky and should give me sound from the freeview once set up.
    The question is - Is it possible to get the sound from the Home cinema working with the dvd player's picture without changing the optical cable from the MR to the dvd player everytime. Or is this not possible when you are just using the cinma system for sound and not picture ?
  2. Renton
    Renton
    Mar 14, 2005
    46
    Bath
    I think you'll need another digi cable going from DVD player to amp
  3. BIGMAX
    BIGMAX
    Jan 11, 2005
    747
    +18
    Problem is that there is only one digital optical connection on the cinema system which is already in use with the sky box and MR ????
  4. Renton
    Renton
    Mar 14, 2005
    46
    Bath
    This product http://www.tvcables.co.uk/cgi-bin/tvcables/SP001.html is intended to split one signal into 2, unsure of the implications of using it the other way though - could be a big no no..?? Need someone with a lot more knowledge than me to confirm or deny that.
    Might be time for a new amp with at least 2 opt inputs?
    Probably no help at all, but hey..!
  5. RobbieTT
    RobbieTT
    Jan 9, 2005
    398
    +6
    Do you not have a spare electrical digital connection free on the amp? You can get elec to optical converters.
    Still think the best advice is to treat yourself to a new amp!
