Advice on component or scart
Discussion in 'Plasma TVs' started by avcar, Jul 28, 2004.
  1. avcar
    avcar
    Jul 14, 2004
    273
    +11
    i have a viera 37" an dvd recorder dmr 85 what is the best way to connect them together scart or component or both? they both have progressive scan connectors
    if i just have component it wont chaged the av channel automatically when dvd is played will it?
    also any recommendations on the scart and compon leads?
    any opinions thanks
  2. Orlando
    Orlando
    Feb 2, 2004
    158
    Essex
    +5
    I have noticed that the viera does not change sources automatically anyway.
    A good component lead is meant to give a better picture than a scart.
    I have just ordered the Thor scart lead to connect up my Sky+ (special offer on this site £17.98) and a composite lead for my DVD (same offer £6.99) These were from TV Cables.co.uk, one of the site sponsors.
    It has a very good picture from cheap supplied cables at present, but for £25 I thought it was worth it for peace of mind.
    P.S if you are using the built in speakers you will have to run a scart cable to the DVD aswell as the composite lead for sound. :smashin:
