Advice on cheap 32in Widescreen
Discussion in 'General TV Discussions Forum' started by nickyvicar, Feb 21, 2003.
  1. nickyvicar
    nickyvicar
    Sep 13, 2002
    284
    Hereford
    +9
    I was, after MONTHS of deliberation, about to purchase a Toshiba 36ZD - now JVC announce what looks likely to be a winner - to be released at the end of this year.
    For the present, I want to buy a 32in WS set as a stop-gap.
    Sound quality is not an issue.
    Thinking of
    LG - £399
    Daewoo - £349 minus stand, £399 complete
    Would have ruled out BEKO after seeing my Mum's 28in but see they have just brought out a 32in 100hz.
    Gentlemen, start your engines,
    any advice gratefully received
    Nick
  2. GaryB
    GaryB
    Nov 12, 2002
    5,387
    St Albans
    +1,294
    Not quite sure which JVC you mean but the new cheap JVC is the AV-28GT1. This is due quite soon. The current AV-28CT1 is quite a good set and may be available for a good price as it is about to be replaced by the GT1.
  3. nickyvicar
    nickyvicar
    Sep 13, 2002
    284
    Hereford
    +9
    The new JVC is a 36" with all the bells & whistles due out December time. Waiting to see if its got PAL Prog.
    Till then I'm looking for a cheap 32".
    LG, Daewoo, Grundig, Goodmans what have you. Not fussed about any features apart from not having a diabolical picture. (bearing in mind Bang/Buck)
