advice on cables please help me get started
Discussion in 'Plasma TVs' started by RonBurgundy, Sep 9, 2005.
  1. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,443
    41
    +21
    not getting much luck in the cables section so someone here may know!
    what cables do i need to connect my harman kardon avr amp / lg pz14 plasma / dvd player (after a hk one at mo!) / sky or freeview box
    and whats the best way to do it??
    complete newbie so dont be affraid to dumb it down completely cz il probably still not understand!
    ps- the way plasma will be on wall about 1m from amp so ideally wouldnt like much cabling running up the wall!
    pps- on a budget so how much will all this cost???!!!
    thanks in advance!
  2. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    Depends on which HK amp you have got / are dreaming of getting! If it is one that can upconvert evry signal thrown at it to component then all you need out from the amp is a component connection (unless the LG does PIP / PAP and you want to use the feature).
    If the amp doesn't do upconversion then you are looking at converter boxes - the J S Technology ones are good as you know having seen one here!
  3. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,443
    41
    +21
    forgot PS2
    somebody please????
  4. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,443
    41
    +21
    piers its an AVR 505 LE
    and yes... i have it sat here next to me!!
    i pick the plasma up on sunday and i have the kef 3005s in the next room also ready to go!
  5. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,443
    41
    +21
    plasma spec:
    - Size : 42 inch (106cm)
    - Aspect Ratio : 16:9
    - Resolution : 852 x 480
    - Brightness : 750 cd/m
    - Contrast Ratio : 1000:1
    - View Angle : Min 160 degrees
    - Colours : (R,G,B) 16.7 mill
    - Input Signal : NTSC/PAL/SECAM, HD, VGA-SXGA
    - Aspect ratio Correction : Auto/Normal/Wide/14:9/Zoom
    - Picture Control : Con/Bri/Colour/Sharp/Tint (For NTSC)
    - Audio Output : 10W x 2
    - RGB In (D-sub 15pin) : 1
    - RGB Out (D-sub 15pin) : 1
    - AC input : 100-240V, 50/60 Hz (Power Cable Included)
    im under no illusions thats its a great panel but its my first and it will do a job for the first 6months at the price im paying!
  6. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    The 505 LE doesn't appear to do upconversion, in fact having read the online user manual it seems to be pre-component. It ain't going to be easy hooking everything up. I am conscious of the fact that I am not allowed to solicit for business but equally I am keen to help out someone starting out on the AV road. Give me a call mate, I am not trying to sell you anything.
  7. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,443
    41
    +21
    ok piers will be in touch soon shall i use number on leaflet from demo?
    what are your immediate thoughts on the way forward?
