F
Fartman
I am lookin to buy an LCD TV soon but I am tbi confused on wat I should buy.
The TV itself will be used for XBOX 360, PS3 (near future), PC, and freeview which mean I need the TV to have decent SD output. searchin around I have come with a couple of TV's I am considering but some dont have reviews so it hard to tell how good these TV's are and reviews never really report longterm problems with the set. The size of the TV is between 32" for a 720p and upto 40"for 1080p
I know the rule is a decent 720p set beats a cheap 1080p set
32"
SONY KDL_32S3000- (cheapest sony for £550 inc Dev)
SONY KDL_32D3000- (price £750 inc Dev) But is the extra 200 worth it especially wen most of the features are unoticable on the 32". including the fact that it accepts 1080p signals witch seem useless considering it cant output it.
Samsung LE32M87- (price £600 inc Dev)
37"
TOSHIBA 37X3030D- (price £730 inc dev) low price 1080p but do u pay the price ?
40"
Samsung LE40LM87- (Price 750 using discount)high reviews but forums show alot of firmware probs
My total budget is about 800 max
P.S the money I save from my 800 goes towards buying a PS3 unless the saving aren't significant to witch I have to wait till december for the ps3...... an by that I meanas in if I buy the Sony KDL 32S3000 I have 350 left which would be spent on a PS3.
And there is my dilemma ( is a 720p TV with a PS3 better than a 1080p TV with no PS3) I would aprecciate ur help
32"
37"
40"
