Advice on Buying a Toshiba DR-1 or Sony DVPNS730
Discussion in 'Blu-ray & DVD Players & Recorders' started by royster, Jan 1, 2004.
  1. royster
    royster
    I need to get a new DVD player and was recently looking at the Toshiba DR-1 which looks very interested, especially has it's got Progressive PAL/NTSC in a recorder.
    Can anyone describe the quality of the pictures you get out of this player. Whats the progressive quality like (NTSC & PAL) and does this DVD player have any other issues which I should be aware of. eg. Lip-syncing
    Can anyone say if the toshiba 3:2 pulldown makes any difference?
    Does the player take along time to recognise discs?
    If not purchasing this DVD player I will probably get the Sony player instead.
    Sorry for all the questions.
    Any help much appreciated.
  2. rudelad
    rudelad
    I had toshiba DR-1 for about a week before if went faulty. Don't let this put you of, I must of been unlucky. The picture quality is excellent, I had no problems with lip-sync. It does take extremely long to recognise disks and also takes a long time to shut down. I now have a Panny E60 and I think it is a much better unit. It has all the features except for support for DVD-RW but you would only use DVD-RW or DVD-RAM I don't think you have need use for both. The Panny seems much faster in operation.
  3. jgar
    jgar
    Dec 3, 2002
    50
    Does anyone know where to find the user manual for the DR1 online?
    @rudelad
    Does the panny or toshiba record in 16:9 or just 4:3?
    Thanx and happy new year.
  4. aMb
    aMb
    Dec 7, 2003
    25
  5. rudelad
    rudelad
    They both will record in 16:9 or 4:3 depands on the source and your settings
  6. BigRD
    BigRD
    Jul 4, 2003
    393
    far far away
    +14
    I've ordered the DR1 and should have it by Mon 5th or Tues 6th Jan.
    I'll let you all know how I get on with it.
    The DVD-RW support is useful if you want to copy recordings to a PC to edit. Most PC drives don't support RAM.
    Saying that I'm considering an LG4040 which supports all formats including DVD-RAM.
  7. bobbles
    bobbles
    with the tosh you can set the aspet ratio flag
    so all recordings to -r appear widescreen
    personally out of the two I think the tosh is a better bet since as usual the sony unit is way overpriced
  8. jgar
    jgar
    Dec 3, 2002
    50
    Thanx guys, think i'll demo the tosh:)
  9. jgar
    jgar
    Dec 3, 2002
    50
    Been reading through the user manual, one of the notes on page 34 states "• Even if you set “Aspect Ratio (Video mode)” to “16:9”, images are recorded in 4:3 aspect ratio when using a DVD-R or DVD-RW disc with “Rate” set to “1.4” (Mbps)."
    Does this mean you can only choose the record ratio when using RAM?
  10. bobbles
    bobbles
    no, the aspect flag is for burnt -r only
    it means you can not set the aspect ratio to recordings made at the 1.4Mbs recording rate. You can with every other recording rate 2.0Mbs - 9.2Mbs
    this is the lowest setting (poorest pq) and I doubt very much it will be used to archive
  11. jgar
    jgar
    Dec 3, 2002
    50
    Thanx Bob.
