Advice on buying a projector
Discussion in 'Projectors, Screens & Video Processors' started by aetbaar, Jan 15, 2005.
  1. aetbaar
    aetbaar
    I wanted some projector buying advice
    Basically I have read the forums in detail and things seem to be so complicated it puts you off buying one
    Basically I am looking for a simple cost effective projector- that has 16:9, quiet, I am not sure whether to go LCD or not
    This is mainly to watch DVD's via DVD player
    The projector can be up to 12 ft away if needed
    I have heard about the epson tw10 and the panasonic ptae-200 or 300 (what is the diff between these)
    can anyone recommend me something to get
    also i would want to connect my projector so i can watch sky- what would i need to do this- cables etc, projector connections
    any help appreciated...
  2. jamiev
    jamiev
    Jan 4, 2004
    923
    +36
    i bought a sanyo z2 and i am still amazed, it is a high end lcd pj.
    go to www.projectorcentral.com to get ideas on distances etc, they have a projection calculator you can use!
    good luck
