calvind123
I currently have a 5.1.2 system with wall mounted KEF LS50s and a r200c centre speaker on a unit in from, as you can see from the picture below. I'm really happy with the sound but I'm not keen on how things look, I am aware that wall mounting the KEFs is far from ideal as well but trying to keep them out of the wall of a young child. I have some Cambridge Audio Minx 22 as surrounds which sound OK but I feel they are a bit small compared to everything else so I eventually plan to upgrade them to something like the Monitor Audio Apex A10s as I can't have anything much bigger.
What I was thinking was to build a stud wall and mount some in wall speakers in it for the front 3, and move all of my devices into the storage cupboard under the stairs, which is the other side of the wall to the TV. I have attached a plan of the downstairs. What I am debating is rather to have a full height wall with speakers either side of the TV and the centre underneath with the TV recessed into the wall, or to have a shorter wall with 3 identical speakers underneath. My wife is OK with either. I have a couple of people that would be able to help me with the work so the costs are just going to be materials. Total budget is probably going to be about £1000 - £1200 for everything including the new speakers (front 3 only, upgrading the rears is a future purchase).
My question is which of two layouts is likely to sound better, or would there be a difference at all? I am aware of the limitations of the wall, it's quite narrow and the right speaker is very close to the wall which is far from ideal but unfortunately there isn't much I can do about that I don't think.
Speakers wise I like the look of the KEF Ci4100QL-THX if I was to go with the full wall option, or something like the KEF Ci200QS or Dali Phantom H-60 if it was the shorter wall option.
Has anyone got any idea what might be best layout wise or any other options for speakers? My issue with any of the Dali speakers is they only seem to be purchasable in pairs, I've not found anywhere selling them individually.
If I was going for a shorter wall it could have a depth of up to around 15cm which I think would allow me a good choice of speakers, if it was a full wall it would probably be a maximum of 10cm depth which I don't think is still too much of an issue as most speakers seem to be at most 10cm depth.
I have attached some photos of the room and a rough plan of what I think the two possible layouts could be. My subwoofer is a SVS SB2000 which is located in the corner under the table. The Atmos speakers are B&W CCM664 but they are potentially faulty so may need to be replaced at some point as well.
Edit: Forgot to say one of my concerns is the difference in sound quality between what I've got currently and the in-wall speakers that are within my budget. I don't really know how in-walls compare but based purely on price what I've currently got cost quite a bit more new than what I'm looking at buying but there doesn't seem to be much in the way of second hand in wall speakers for sale.
