Question Advice on best satellite speakers
Discussion in 'What Speakers Should I Buy?' started by Simon14, Jul 13, 2015.
  1. Simon14
    Simon14
    Jun 6, 2014
    20
    I need new satellite size speakers but don't want to use a sub. Is there any small corner mountable speakers with amazing sub built-in to them? Good for listening to music and movie's.
    Not got a budget but lower the price the better.
  2. PSM1
    PSM1
    Dec 20, 2008
    26,285
    +5,443
    What is your budget?
    You are basically asking for the impossible. To make bass you need a reasonable sized speaker/driver. This is not possible on a small satellite speaker. Something like the bigger Monitor Audio Apex speakers can make a reasonable sound but still really need a sub for the low stuff.
    You are not going to get a low priced satellite speaker that is going to be good for music and movies without a sub.
  3. Simon14
    Simon14
    Jun 6, 2014
    20
    Thanks for the info PSM1, really there is no budget. So can you recommend some more?
  4. PSM1
    PSM1
    Dec 20, 2008
    26,285
    +5,443
    How small do they need to be?
  5. Simon14
    Simon14
    Jun 6, 2014
    20
    They will used up in corners, so their out of view. I don't have measurements as will be for our new home which is still being built.
  6. Simon14
    Simon14
    Jun 6, 2014
    20
    Also to note, I've got a Yamaha RXV777 AVR.
  7. PSM1
    PSM1
    Dec 20, 2008
    26,285
    +5,443
    Orb make good small speakers but they will need a sub. Putting speakers up in a corner is also far from ideal but suggests you want a very small speaker i.e. the Apex will be too big. Again this is going against your requirements for good for music.
    You are either going to have to compromise in terms of position or compromise in terms of the sound you will get.
  8. Simon14
    Simon14
    Jun 6, 2014
    20
    Unfortunately positioning isn't ideal but it's the best I'm getting.
    Yeah I'm probably going to have to with the sub, what do you think about the Monitor Audio Mass 5.1?
  9. PSM1
    PSM1
    Dec 20, 2008
    26,285
    +5,443
    The Mass are a budget satellite system so will be OK with movies but may not be the best for music. Go have a listen and see what you think.
  10. Simon14
    Simon14
    Jun 6, 2014
    20
    D you ave any better recommendations for music?
  11. PSM1
    PSM1
    Dec 20, 2008
    26,285
    +5,443
    Not in the price bracket and size. Standmount are what you would need for good music at your budget.
  12. Simon14
    Simon14
    Jun 6, 2014
    20
    Thanks again PSM1, which are best out of these with my Yamaha avr:
    Dali Fazon Mikro, Monitor Audio Mass or Cambridge Audio Minx S225?
  13. PSM1
    PSM1
    Dec 20, 2008
    26,285
    +5,443
    All should be fine with the Yamaha receiver. Try to demo if possible as the best will depend on your personal preference.
  14. Simon14
    Simon14
    Jun 6, 2014
    20
    ok, found some other useful post's! So thinking of going down the 5x B&W M1's with a BK Sub?
    What's your thought on that?
  15. dogfonos
    dogfonos
    Jul 13, 2011
    1,853
    83
    +310
  16. Simon14
    Simon14
    Jun 6, 2014
    20
    Thanks dogfonos, are those suggestions better than BK xls200 or Gemini 2?
  17. dogfonos
    dogfonos
    Jul 13, 2011
    1,853
    83
    +310
    In terms of sound quality, I very much doubt it but I haven't heard any of these so I can't say for certain.
    As PSM1 has already said, with subwoofers, it's the bigger the better (all else being equal). Some of the best subs occupy as much space as a small room and aren't domestically acceptable to most of us.
    Horn Subwoofer Takes Up Crazy Man's Entire Basement
    If you intend to mount the front L/R speaker pair in corners then I wouldn't spend too much on them because I'm unaware of any speakers (satellite or otherwise) that will sound good in such a location (i.e. even quality gear will likely sound poor when mounted in a corner). Maybe 'in-ceiling' speakers would be a better compromise but I don't know anything about them other than that they are designed to function 'in-ceiling'.
  18. Simon14
    Simon14
    Jun 6, 2014
    20
    So it's either going to be B&W M1's with a BK Sub or Focal Dome's with BK Sub.
    Which out of these 2 are best?
  19. PSM1
    PSM1
    Dec 20, 2008
    26,285
    +5,443
    I have always liked the m1s for the sound they produce for their size. Not heard the domes but like focal speakers in general. So a difficult choice. Really need to listen to both yourself and make your own mind up. Otherwise do not think either option is going to dissappoint.
  20. dogfonos
    dogfonos
    Jul 13, 2011
    1,853
    83
    +310
    Can't comment on best sounding speaker set as I've not heard either the B&W M1's or the Focal Domes but agree with PSM1 - judging by reviews I've seen, I suspect you'd be happy with either. In general, these sort of 'lifestyle' speakers that compromise function for form don't interest me.
  21. Simon14
    Simon14
    Jun 6, 2014
    20
    Thanks again for the advice guys. I've bought the Focal's, should be with me soon but can't use until at least another 3months while house is being built.
