dollag
I’m seeking some advice on what to do going forward.
Currently using my avr550 for both my music and movie needs; genuinely happy with the performance. Problem is I’ve upgraded my htpc which I use for gaming and due to hdmi 2.1, have plugged it directly to the TV and using arc for everything. I find myself using my pc or TV for everything so having eARC or getting a 2.1 compatible avr seems to be On the cards. The caveat is that whilst listening using roon on my pc, everything is converted to 48khz
I have no issue keeping my pc connected directly to the tv and using eARC as long as the avr I upgrade is roon certified so have come to the conclusion that I don’t really need hdmi 2.1. this begs the question, what do I do to obtain eARC? I did consider using a pi as an endpoint but the reality is what’s the point when there is avrs on the market that have this base covered.
shortlist:
Nad t778
arcam avr20
Arcam avr30
These both seem to be the logical choices and also throw in anthems latest range too although not sure if they are roon ready. One issue is the onngoing issues they’ve had, although I believe they have been rectified.
An alternative solution I’ve been considering is that I get something like a denon 3600 avr, along with a Lyngdorf tdai 3700. This is a more expensive solution but am willing to commit if the benefits are worth it. My use case is 50/50 so a good stereo amplifier wouldn’t be wasted, and being roon ready, can just slot in and cover all my music needs.
My biggest issue is room eq and the integration of using the 3400. Set up audyssey and bypass l&r whilst setting to full range would allow the 3400 to manage my mains and 2 subs. My concern is the LCR and how this would affect the lcr stage with room perfect doing lfe and mains whilst audyssey is managing the rest?
Would doing this be compromising the surround experience in any way rather than using a dedicated receiver and allowing Dirac to manage everything ?
Any feedback, experience would be appreciated
shortlist:
Nad t778
arcam avr20
Arcam avr30
