Advice on an HD-DVD player
Discussion in 'Blu-ray & DVD Players & Recorders' started by Kammando90, Feb 19, 2014.
  1. Kammando90
    Kammando90
    Feb 19, 2014
    15
    I know no one probably has this, but out of love of collecting I would to own one of these players.
    Just before I buy I want to know if any one had any issues with any specific models. I heard the Toshiba-A1 were pretty bad. Which models are solid?
  2. Gaspode_TWD
    Gaspode_TWD
    Jun 3, 2008
    720
    Thame
    +69
    Mine is a Toshiba HD-XE1 which I bought 2nd hand. No issues or problems so far.
  3. Kammando90
    Kammando90
    Feb 19, 2014
    15
    how long have you used it?
    Do you use it regularly or you switch it on once every 3 to 4 months?
  4. Gaspode_TWD
    Gaspode_TWD
    Jun 3, 2008
    720
    Thame
    +69
    I bought it from this site in May last year. Took a few months to get the system connected, so its probably be on since October and used about 2 times a month.
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I have two A1s, XA1, XE1 and some EPs, no issues with any. The A1 and XA1 re great players only bettered by XE1 but there is something special about the battleship build. The lesser players were the EPs...but still reliable.
  6. Kammando90
    Kammando90
    Feb 19, 2014
    15
    There is almost no XE1 listings on ebay. I can't believe these players are so rare.
  7. Geoff_D
    Geoff_D
    Feb 14, 2005
    11,868
    167
    Spider Skull Island
    +5,811
    The XE1 was a tasty bit of kit.
