Advice on amp choice please
-DT-
Established Member
I have my JMLab 816S speakers hooked up to An Audiolab 8000P and S (old ones from the 80s) but the audiolab seems to be dying a slow death and the GF thinks it's all too big and ugly anyway.
Can anyone suggest a couple of new or used amps that might pair well with the 816S's? This system is for music only. Main sources would be HQ streaming services and a record player.
The 816's are slightly bass light, but quite accurate/ 'quick' speakers so I am guessing an amp on the warmer side might work well? Budget is probably up to £500.
Preferably I would like something that is an integrated pre and power amp if possible as ideally I want to have it out in the room and I don't think the GF will tolerate a '2 box' setup being out. I can put it all away in a cupboard if I have to but cabling will be a bit of a nightmare.
Thanks for any suggestions!
muljao
-DT-
Established Member
Thanks for this!
I have read that on the sound front, JMLab Focal stuff tends to be a bit 'light' for Yamaha/ Onkyo stuff though. i will investigate these options though...
LG G3 MLA OLED Evo Best Picture Settings - works for ALL 2023 LG OLEDs
Back
