Advice on Amateur Studio setup
chrisebabey
I'm looking for advice on Lighting / Backdrops for some Amateur Studio work. Its for Baby and Animal Portriats, i'm guessing i would need 2 good daylight lights and a neutral backdrop. If anyone has a simular setup and can point me in the right direction i would be most grateful.
My Kit is a Nikon D50 with the kit lense of a D70 (18-70)
C/B
redmax
I purchased some Elinchrom studio flash heads and use colorama paper which comes in a zillion colours depending on what mood you want to convey.
I dont know what you mean by daylight lights but if your referring to the old tungsten daylight heads I think they are not so widely used anymore in studios.
Flash is the way to go IMHO because it is temperature stable and very little heat.
The D-Lite 2 are digital so are adjustable to 1/10 of a stop on a 5 stop range. Thats about as goods as it gets even for the pro stuff which works over a 6 stop range
Beware cheap Chnese imports on fleabay etc.
I got mine here
Old thread posted here
Hope this helps
