viKierannx
Hello everyone,
First post here so I apologize in advance if things don't make sense, and I thought this would be the relevant place to ask this question.
I'm looking at this: XFX HD6850;
XFX AMD Radeon HD 6850 1024MB GDDR5 | HD-685X-ZCFC
But I'm a little concerned about power usage on this and the amps it uses. I've used Performance Comparison Benchmarks @ Hardware Compare to see the power it uses but I was wondering if my PSU will be able to support this. I've also been looking at forums trying to find an answer.
My specs are;
i5 2550k @ 3.4GHZ
8GB G.Skill RipJaws X @ 1600MHz
Gigabyte GA-Z68AP-D3
HIS HD4850 512MB
AVerMedia AverTV H727 CaptureHD
Lite-On DVD-RW Drive
2 HDD's
1 SSD
3 120mm Fans
2 80mm Fans
Gelid Tranquillo Rev.2 CPU Cooler
Corsair HX520W PSU
Zalman Z11 Plus
So basically with all of the above can I run the XFX 6850 on my Corsair HX520W PSU? Or would I need to upgrade that too? Which I don't really want to do at the moment.
Regards,
Kieran
My specs are;
i5 2550k @ 3.4GHZ
HIS HD4850 512MB
2 HDD's
1 SSD
3 120mm Fans
2 80mm Fans
Corsair HX520W PSU
Zalman Z11 Plus
Regards,
Kieran
