Eggman
Im looking to purchase an in-ceiling mounted projector screen with a 110" screen size for a JVC X5900 (which is about 4m away). The room is not a bat cave (has windows and is untreated) but Ill be mostly watching films after it gets dark (kids may watch their films during light hours). The screen will be fitted into a bulk head which is 2200mm off the ground and the centre speaker is to be in-wall at 450mm off the ground. The L and R front speakers are also in-wall and designed to be set 2680mm apart.
Could you please advice on the screen type and material for this setup? My price ceiling is around £1500 (but would ideally like to stay closer to £1000).
Thanks for any advice you can provide
BW
Andrew
BW
Andrew
