Advice on a new sub
Discussion in 'Subwoofers' started by say1, Dec 10, 2004.
  1. say1
    say1
    Sep 8, 2004
    105
    Hi all,
    I am currently in the market for a sub around £1k. I will be using it mainly for HT (75/25).
    Speakers:-Fronts Q7's,Center Q9c,Surround Kef eggs
    Room Size:-12.5'X26.5' opening to 8.5'X10'
    Any help/advice would be welcomed
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Did you ever discover what the problem was with the SVS that you had ?
    Non SVS subs worth considering will include the B&W ASW750 which a few here have tried and liked.
  3. say1
    say1
    Sep 8, 2004
    105
    Hi Ian,
    As you know I sent the pb2-plus/2 back to SVS.Erik/Tom said they couldn't find anything wrong with it but personally I believe there was Earthing problem.
  4. Stonedragon
    Stonedragon
    Jul 9, 2004
    158
    I agree with Ian J, you can pick up a new 750 for a grand or less if you're prepared to buy seconhand from some members of this site. I've heard the 750 and for its size its the dogs b****ks!!! :thumbsup:
  5. Pat Marcus
    Pat Marcus
    Oct 29, 2004
    610
    Ibstock
    +8
    Consider the fanatastic new PV1, too.
    Tight as tight can be.
