Advice on 3.5mm phone rca adaptor
C225
No it wont you need a cable with female rca plugs that cable has male rca plugs.
REALDEAL
r u sure m8
can u show me(link) to the correct one
thanx
ben searching for ages thought i had found the correct one.:(
Batch
C225
sorry i just looked at the bottom like you said :oops:
Similar threads
