Advice on 2nd hand digibox
Discussion in 'Satellite TV, Sky TV & FreeSat' started by cerebros, Aug 16, 2004.
  1. cerebros
    cerebros
    Dec 27, 2002
    1,293
    48
    Leicester
    +29
    I'm looking to get a 2nd hand digibox, probably from eBay.
    Are there any models I should avoid like the plague, or are they all much of a muchness?
    cheers
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Avoid the first generation models from Pace and Amstrad.
    Basically the newer/younger the digibox the better both in terms of reliabilty and menu speeds.
  3. cerebros
    cerebros
    Dec 27, 2002
    1,293
    48
    Leicester
    +29
    Do you have the model numbers for he first generation? Sorry, not terribly up on Sky digiboxes (hence the reason for the thread) so i wouldn't know a 1st generation box if it bit me...
  4. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,117
    Southampton
    +262
    With regards Pace - the 3100 is the newer version,and the 3000 is a older type.Not sure about the others,but then Pace is probably the one to go for IMHO.
  5. w3dal
    w3dal
    Aug 4, 2002
    5,050
    Chelmsford, Essex
    +587
    check out www.digiboxes.net
    They have some of the older models for sale with pictures.
    Dal
  6. Fernsehman
    Fernsehman
    The only Sky Digibox that doesn't seem to have reliability or software issues right now is the Pace BSKYB2600 and its recent upgrade called the DS430N.
  7. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    PACE 2200
    Amstrad DRX100
    Alogn with the link w3dal posted check this one out as well.
  8. cerebros
    cerebros
    Dec 27, 2002
    1,293
    48
    Leicester
    +29
    cheers guys
  9. Tyz
    Tyz
    Nov 1, 2005
    24
    Just won Pace DS430N on e-bay to replace old amstrad box, is there any problems that can arise in installation or getting it to work?
    If box is still on contract or stolen? or am i just to pessimistic..
    Tyz.. :confused:
