Advice on 28" widescreen
Discussion in 'General TV Discussions Forum' started by cky, Nov 22, 2004.
  1. cky
    cky
    Hi all,
    My current Philips 28PW6332/05 had a problem this afternoon. Was watching as normal then heard a small pop, the screen just went black and the standyby light started flickering. No idea what's gone - has anyone experienced this or know what's gone? :confused:
    Preferably want the Philips repaired but I'm already looking for a replacement in case the worse news comes back from repairers. With so many TVs out there I really dunno where to start other than ask the pros here....anything to recommend that's under £400.
    :lease:
    Thanks in advance.
    Dave
  2. Barrovian
    Barrovian
    Oct 29, 2002
    982
    Second star to the right and straight on 'till mor
    +79
    Can't be specific, I'm afraid but this sounds exactly like a problem I had with my Philips a couple of years ago. It was put down to a dry solder joint (or something :confused: ). The bad news is it wasn't something that could be fixed there and then. It was away for about two weeks being repaired. I think it cost me about £100 to fix.
